Anything worth keeping from a wrecked e36 excpet engine swap
Edelweiss
Post Sat Nov 11, 2017 5:11 am
Hello e30 zone. Long time reader, first time writer.
Here's my situation: Tomorrow I'm going to look at an 84 318i that includes a wrecked 92 325 for the engine swap. Other than the motor and all it's acessories, what can I salvage from the e36 that can be used on an e30? Also, I've read the engine swap info and know i need the engine's harness or loom, but is there anything else I'll want to make sure I take? ECU?
Any and all help is much appreciated from California! Cheers :cheers:
deep-dish-e30
Post Sat Nov 11, 2017 12:04 pm
List it on eBay I'm sure someone want some parts you be surprised good luck
pukar
Post Sun Nov 12, 2017 10:58 am
if its an early one, the torch might be good?
HRH-squidlips_III
Post Sun Nov 12, 2017 6:08 pm
radiator and + battery cable keep the car till youv,e finish your swap youll be supprised what little things you can use
Edelweiss
Post Mon Nov 13, 2017 5:31 am
thanks for the advice. what do you mean torch?
ChrisHC
E30Zone Contributor
Post Mon Nov 13, 2017 12:44 pm
Edelweiss wrote:thanks for the advice. what do you mean torch?
Probably the rechargeable small torch in the glove box, the E30 has the same.
Tedswagon
Post Mon Nov 13, 2017 1:07 pm
The prop shaft
Ro3345
Post Wed Nov 29, 2017 5:06 pm
e36 outer tie rods come in handy for E46 steering rack swap.
