clio servo swap probs
steve_k
Post Mon Oct 09, 2017 9:11 pm
evening folks, on the hunt for a bit of advice.
recently i did a clio servo/25mm M/C swap as i've had 4 pot calipers on the front a fair while with bigger disks. (original M/C was leaking & the diaphragm in the servo had gone).
now when i fitted the servo i had to push the clevis fork forward a good 15mm++ to get it to line up with the brake bar/spring.
checked the brake pedal & that is where it should be/where it was before (from what i can see),
now, whats the best way to adjust the bar/spring so that i don't have to push the clevis so far forward??
do i start with the bar from the peddle or the spring it connects to??
any help/advice/pictures would be fantastic,
Post Tue Oct 10, 2017 10:03 pm
Replied to your facefook post yesterday I think Steve, did you get anywhere?
steve_k
Post Wed Oct 11, 2017 8:21 am
DanThe wrote:Replied to your facefook post yesterday I think Steve, did you get anywhere?
yes dude, got it sorted thanks :thumb: but got a nicely scraped knuckle :(
