Hi folks. I've just filled my 325i with coolant after re-fitting the cylinder head. It has a new thermostat and water pump. It has been bled. Before any work was carried out it never went any higher than just under halfway on the temp gauge.
At idle it now creeps over the halfway mark. When I take the revs up to about 2000 rpm for about 20 secs the temp will dip below the halfway mark.
Not sure what to do with it now. Perhaps more bleeding required?
Running a little bit hot after head re-fit
Yes, bleed it again until you purge the system of any air pockets. Keep the heater on while you do it.
Don't forget, it is unusually warm at the moment!
BenHar
It is also possible that you have fitted a thermostat from a four cylinder engine which opens at 88 degrees. Six cylinder engines should have an 82 degree thermostat.
Ben
Ben
jimf
jimf
Doesn't matter where the heater dial is when you initially fill and bleed the system with the engine off, but when the engine is running, the dial must be more than 15 degrees away from the fully cold position for everything to bleed properly.
BenHar
Sorry about the bum steer.jimf wrote:You got me thinking there Ben, took the T/stat back out and it's the right one.BenHar wrote:It is also possible that you have fitted a thermostat from a four cylinder engine which opens at 88 degrees. Six cylinder engines should have an 82 degree thermostat.
Ben
Probably needs more bleeding.
Ben
