325i sport suspension
Nickerz
Post Sun Aug 20, 2017 7:54 am
Looking to replace shocks springs and top mounts. What's a good replacement? Looking for standard height running standard tyres car is not to be used on track. I've heard B4 front and rear and e46 cab rear top mounts?
tha881
Post Sun Aug 20, 2017 10:39 am
If you want standard sport springs then your only option will be to buy them from bmw. If the car still has oem sport springs then replacing just the dampers and bushes might be enough
jmc330i
Post Sun Aug 20, 2017 10:52 am
I'd go for the Bilstein B12 kit - Bilstein B8s and Eibach springs. It gives a 30mm drop, so 15mm lower than OEM Sport springs and gives a decent ride without having to worry about speed bumps and shite roads.
And yes, E46 cab rear top mounts are the ones to go for.
James
'91 325i Sport
'93 318i touring 16v
