Bonnet adjustment
Cloggy Saint
Post Fri Aug 18, 2017 12:03 am
I know the hinged end of the bonnet can be raised or lowered with the rubber stops but can the other end also be adjusted?
Post Fri Aug 18, 2017 1:26 am
Yes, the 2 side catches can be loosened and lowered or raised.
Cloggy Saint
Post Fri Aug 18, 2017 9:25 am
Great, thanks.
paultv
Post Fri Aug 18, 2017 12:21 pm
The hinged end also has vertical adjust on the sides of the mounting brackets - one bolt hole on each side is slotted.
Paul :-)
