brake servo location, freeing room
tim_s
Post Thu Jan 26, 2006 11:34 pm
can the brake servo be flipped 180 or 90 degrees without any hickups? want the vacuum take-off out of the way to give me more room for my plenum. what other (cheap!) options do i have to clear up some space in the m/c + servo area? i know golf servo potentially, what about remote m/c tank etc? any ideas appreciated, really want to clear up some room around there rather than sacrifice airflow/trumpet length/plenum design.
Cheers all
tim
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
Post Sat Jan 28, 2006 12:28 am
All options have been discussed in length on the engine swaps forum, usually in M50 conversion threads, so do a search.
There was a pic on here somewhere a couple of days ago of an E30 with the servo/MC mounted right behyind the LH headlamp. Presumably, with a very long pushrod.
On my own M50 I moved the servo sideways towards the outside of the car as far as it would go and used a longer pull rod across inside the car.
Demlotcrew
Post Sat Jan 28, 2006 10:19 am
Tim if you look on six and M3 cars the vacume line is on the other side of the servo. HTH
Andrew
tim_s
Post Sat Jan 28, 2006 10:37 am
too right it helps andrew! is the same part no as the 318is one so i'm guessing i can just flip it 180 degrees :cool:
that should give me enough clearance. are the bolts for the servo inside the car?
i'll have a search too, i didn't realise this had been covered so much, had only read stuff on the golf servos in the past....
cheers guys
Demlotcrew
Post Sat Jan 28, 2006 2:04 pm
Just undo the master from the servo, then go inside the car and undo four nuts and rotate the servo 180deg.
Andrew
tim_s
Post Sat Jan 28, 2006 3:41 pm
cheers andrew. thats what i suspected when i was looking at it all the other day, hadn;t really looked at it properly though. will need this done to fit the s14 plenum.
ideally would like to get the m/c tank out of the way too, but this may prove too much hassle. the plenum only has 1.5cm or so clearance of this tank so if i were to mount the plenum to the engine it would run pretty close when the engine moves. reckon it should be ok though
