im sorry if this has been covered lots but im new to the forum and searched with no results
i have a clio break booster installed in my e30 318, i have the std brake master.
have done an engine conversion and expect to get an easy 250-280bhp from it. Im thinking about running the 280 front brake Wilwood system.
my question is should i change to the 540 25mm master cylinder.
and if i do will i still need the spacer in the booster to master.
i don't have the spacer in the system at the moment i just have the master cylinder adjustment wound all the way out.
