I am about to install a replacement fuel tank, it needs painted to help it last, does anyone have any advice on what type of paint to use I have already used Zinc rich primer, I was going to use hammerite but realise this may be quite hard and not be ideal in dealing with stone damage and flexing in this application.
Does anyone have any ideas on a paint suitable that may be applied by brush.
Regards Glenn
Fuel tank finish
Stefan on probation
Stainless steel tank or galvanised paint.
Only thing I've ever used for the job is black plant enamel, made by Tractol usually, and sold for painting tractors and other agricultural equipment.
steve_k
aswell as tractol there also tekaloid, it's enamel paint for coaches, pretty hard when dried, i've used it on the underside of my sport,Brianmoooore wrote:Only thing I've ever used for the job is black plant enamel, made by Tractol usually, and sold for painting tractors and other agricultural equipment.
even thinking of using it to do the topside as well
tiw30
Thanks Brian and Steve couldn't find much for Tractol earlier but when I searched for tekaloid uo it appeared saying tractol on the tins pictured, I will go with that then.
Many thanks for the help from both of You
Glenn
Glenn
steve_k
Now worries, there's plenty on eBay,
Iirc you can either spray it on or brush/roller it on.
Used it a few times on old landie defenders to good effect.
