- hello,my 325 has reacently been serviced and had a new battery /alternator is working aswel.
The last few days it just stops red lights come up then off,radio goes off,then when I turn the key it fires up againa˜«
If someone could help much appreciated cheersa˜Š
Engine cut out
guss
Since it's recently had a new battery, check all the connections on and around the battery, especially the smaller wires bolted to the positive battery clamp.
guss
Could the ecu have something to do with it,the power felt a little flat
Sometimes . Thanks Brian
Will check the wires
