indicator 2 pin plug to fit 3pin holder?
puregttipower
Post Sun May 21, 2017 11:36 am
Hi guys
i dont a m3 replica conversion on my cabby, the front indicators i had to get from america as they are different shape, but the connection on the american holder has 3 pins and the loom on my e30 has 2 pin? anyone know how to make this work :(
Post Sun May 21, 2017 8:52 pm
US version incorporates a "side light" into the indicator, using a 21W/5W dual filament bulb?
Connect 12 volts across all combinations of the three pins. When you find the pair that makes both filaments glow, the pin NOT connected is earth. Having established this, connect 12 volts between this pin and the other two in turn. The one that gives the brightest light is the second pin for your two indicator wires.
puregttipower
Post Mon May 22, 2017 9:20 am
thank you sir :D
