Differential wiring connector
gd01
Post Wed May 03, 2017 2:48 pm
Hey Guys,
I have an 86 32e converted to a 325i. I changed the diff to a 3.73 ratio from a late model e30.
I noticed that the plugs for the speed sensors are different from the early/late models. How should I connect this? should I change the sensor from the old diff to the new one and let it plug right in, or should I retrofit the newer model sensor to fit my existing connector?
Thanks guys.
