where exactly is it on the box?
I know what it looks like but cant see it on the car, does anyone know?
Reverse switch
Sanchez
Steviec
Dont know if it helps, but its part 25 in this pic:
http://www.realoem.com/bmw/showparts.do ... g=25&fg=05
stulane
im guessing but isnt it on the drivers side of the gearbox about 8" from the back and 3-4" from the bottom? Thats where it is on the M50 trans.
Jami
I have a 1989 320i and the reverse light switch is near the top of the gear box on the drivers side. If you see the linkage going to the gear box from the gear stick, it is just below that.
If you want to test the actual switch without going under the car, remove the gear stick boot (inside the car) and you should see a cable coming up infront of the shifter. Possibly Blue/white and Green/white cables. There is a connector here, so just unplug it and put a multi meter across it, make sure you test the switch end and the not the power!!!!!!
I have a problem with the reverse lights on mine, but i checked the switch and it seems ok!!!!!
If you need any more details let me know, i can take a pciture or something if it helps.
320i SE on 15" BBS in grey with leather to match
Steviec
Mine plays up too, but I think my switch is just getting a bit old and worn.
Im leaving it for a summer job
Sanchez
if just found out why they dont work, and why i couldnt find it.
i was looking for a cable going into the switch on the gear bow but there is no cable
the switch is sheared of, but managed to remove it now of to by a new one.
cheers guys another job done, next for the handbrake.
