Could anyone please advise on how to do this? Is this possible without removing the tray?
Photos to help.
Motor/gearbox now out, metal plates out. Cut myself on those a while back..Brianmoooore wrote:Motor/gearbox should drop down and out after removing its fixing bolts.
For the cable you need to remove multiple small self tapping screws and remove the large stainless steel plates. These have lethally sharp edges, and are a stuck in non setting sealant.
Disconnect the cable from the rest of the mech., and pull them out of the guide tubes.
