Convertible Rear Window Blower
M3KUK
My blower isn't working, any tips?
jimf
1. Check fuse
2. Check wiring to switch *
2. put a 12v supply straigt to the blower plug see if it works.
3. Swap the switch
I'm not sure if there is a relay involved.
*My blower wasn't working, one of the wires to the button had obviously broken when I looked behind the switch.
Too be honest you are not missing much, they are next to useless anyway.
3. Swap the switch
paultv
Relay is attached to the fan/motor unit.
Paul
Paul
Add the top position microswitch to the above. This is the one that stops the blower working when the roof is down.jimf wrote:1. Check fuse
3. Swap the switch
Pull the relay, and link 30 to 87 of its base with a short piece of wire, with the ignition on, as a first check.
M3KUK
Had a look at this today, can hear a click from the relay when switch pressed, looks like motor is knackered.
