Bmw e30 abs help
ibzy
Post Sat Mar 18, 2017 7:16 pm
Just wanted to know can i retrofit a abs system in to my e30.
Post Sun Mar 19, 2017 10:52 am
Yes, but there's a lot of work. All four hubs need to be the type that have the holes for the sensors, and the ABS rings on the bearings/drive shafts. Brackets need to be welded on for the ABS pump.
After that, the wiring is relatively simple. It's all self contained looms, apart from the supply from pin 20 of the C101 engine loom plug.
ibzy
Post Sun Mar 19, 2017 3:29 pm
Brianmoooore wrote:Yes, but there's a lot of work. All four hubs need to be the type that have the holes for the sensors, and the ABS rings on the bearings/drive shafts. Brackets need to be welded on for the ABS pump.
Okay thanks
