frnt wheel bearings
jjoe
does anyone know the size of the frnt hub nut on a 1989 320i please let me know so i can buy the right sized socket for once!
Cava
36mm is the size of a hub nut on a 1990 318is but i think they are the same on all models.
Sooty
Make sure that it's a thin walled one though.
Did this job today and I ended up having to turn a socket down on a lathe so that it could fit into the recess.
Max OD you want is 50mm.
HTH
Iain S
HTH
Iain S
kam-325i
I had to do the same with the socket i bought, used a grinder to take a few mm off...Sooty wrote:Make sure that it's a thin walled one though.
HTH
Iain S
