First question: Are there two linkages connected to the gear box or just the top one?
Question two:
As you can see below I'm in the right spot at the right pin thing.. I'm just not sure how this works. They say it goes in from the drivers side and has a cap on the other. Is what is pictured below that cap and how do I get it off? From what side do I twist, if I twist it at all? I have as I'm sure some of you know, 0 access the other side apart from being able to get my finger on it.
Any help appreciated.
Cheers.
Edit: It's this bit I don't get.
"where you would expect to be a bolt. In fact it's a clip that needs to be flipped upwards through 90 degrees to remove it, and then the "pin" comes out - it's often described as "a right bastard"
Can someone explain in different words maybe?
