If you were gonna get some throttle bodies for a 2.5 M20, what size butterflies would you go for?
I've made mine 40mm, but I'm wondering if that's a bit on the large side so a plan's been hatched to make some castings with smaller bores.
Any thoughts chaps?
Cheers!
M20 throttle per cylinder sizes
Turbo-Brown
- Boost Junkie
Andy335Touring
Sounds about the right size to me as you are turbo charged.
If it was N/A then i'd say around 35mm depending on the spec of the engine ?
Andy335Touring
PM Player6 (?) and see what size his ITB's are ?
Ant
- Retired Team Member
good plan that man !
or see if dbilas have specs online
Email FTW
Turbo-Brown
- Boost Junkie
Think the reverse might actually be true with FI and NA sizes: You can run smaller throttles/inlet cross sectional areas as the greater pressure differential across the inlet system at higher revs with the turbo negates the restriction.
