I cut an aftermarket alarm out and now my car wont start!
MiniC
Hey all, i have a 318i and wanted to install a new stereo but someone has messed around with the loom before and it has a pirahna alarm system installed. I wanted to remove that as i have everything apart so i cut all the wires and removed it thinking it would not affect anything else but now my car will crank but not start. Isthad a small plug with 2 green wires soldered onto the aftermaket alarm that looked original was wondering if thats the reason. Please help!.
milescook
A green wire often needs joining for her to fire, the one usually intercepted by the OBC immobiliser.
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
milescook
Find the two pin plug with the green wires that you've removed, cut and solder the green wires so that they just form a loop connected to the two pins of the plug, and then plug it into the socket you removed it from behind the glovebox.
