Hi, does anyone have the plumbing drawings for the intensive and normal wash for the windscreen. there is not a drawing on REAL OEM.
I guess that both pipes run up the bonnet side, through a T piece so there is a single output to the washer jet ? I need to order the T pieces but i've also seen pictures with large white things in line with the pipework - what are they for ?
thanks
Windscreen intensive and normal plumbing
- Brianmoooore
But there is in the zone wiki!jimbom30cab wrote:Hi, does anyone have the plumbing drawings for the intensive and normal wash for the windscreen. there is not a drawing on REAL OEM.
Click on the wiki tab that is a sub section of E30 Tech help, rather than the one in the header, select the post that refers to Retrofit Guides, and that will lead you the guides themselves, one of which refers to the installation of intensive wash.
jimbom30cab
- Tech 1 freak
Thanks, i'll check it and thanks for the tip, i wasn't sure if they were one way or non-drip valves.
