Hi both headlight adjusters on my Cab are not working.
I know they are troublesome, just need to get the passenger side one 'up' as the headlight is pointing down.
Any ideas?
Ta Mike.
Headlight Adjusters U/S
Wind it up on the 'coarse' adjustment (the threaded rod that goes from the hydraulic cylinder over to the headlamp), then accurately set the aim with the 'fine' adjuster - the knurled ring around the outside of the cylinder.
