1500-2000 rpm runs sh1t.
ah
Just put a brand new dizzy cap + rotor arm on to try and sort my ongoing fault but no such luck.For those who don't know my fault,between the shown rpm it miss fires and kangaroos,after that it flies.Ive tried almost everything I can think of apart from fuel injector service,it's done 112k.Any ideas? It may still be missing after above revs but under hard acceleration and high speed it's a job to know.Also on idle I'm sure its missing.
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
ah
Thanks guys,I have had a good look for air leaks,but couldn't find anything.I would like to do one of those smoke tests to be more conclusive.
Jona1971
Mines the same and I've had my injectors cleaned.
Convinced its an air leak but can't find it.
I've just bought some smoke test matches...
Moredoor autos with small engines are cool - but my new m20b25 is awesome!
ah
Please let me know the results from the smoke test.Jona1971 wrote:Mines the same and I've had my injectors cleaned.
JackCornick
I'm currently having a similar issues between 2000-2500 rpm. I'm guessing at the moment it's the fuel pressure regulator. It only happens on partial throttle, full throttle its fine. I'm trying to find the how t, but Iv read on the forum if you disconnect the vacuum hose from the inlet manifold and plug it up, the the regulator will run at full fuel pressure 3bar. If running at this pressure cures the issue, then the regulator needs to be replaced. Obviously running at full pressure for a prolonged period isn't recommended. I have yet to try this, but it's next on my list a‘aaa»
You can't polish a turd, but you can paint it matte black
Jona1971
let us know how you get on
If problems with ignition components have been eliminated, the next thing I'd check for problems at light throttle is the AFM. Easily tested with a 6 or 9 volt battery and a meter.
Jona1971
How do I do thatBrian?
Jona1971
I've isolated the brake servo to rocker cover pipe and its running much better. (Brakes need a heavy right foot though)
When the replacement pipe arrives I'll plug it all in and see what's what...
Jona1971
2 years of messing about and 5 quids worth of rubber pipe fixes it, result. a˜€
Connect the battery across the pot. and measure the voltage on the wiper contact as you move the flap from closed to fully open by hand. I'm sure it's all detailed in the wiki, but it looks like it's irrelevant now.Jona1971 wrote:How do I do thatBrian?
Congratulations on finding the main problem - an air leak after all, but don't assume that the rest of your investigations have been a waste of time. Chances are that you've eliminated other small problems along the way, and now the car is operating as BMW intended. There's no reason why, after 30 years and 100k - 200k miles, that these engines can't still produce every single one of their original BHP.
Jona1971
That brilliant, thanks Brian.
Let's hope the OP can solve his problem too. a˜€
Ooops! Thought you were the OP.
