Hi fuel gauge on my 325i has just started playing up.
It's dancing all over the place! Any ideas what it could be?
Dancing fuel gauge!
DHFiS
Brass nut on the back that earths the gauge to the circuit board?
That's the first thing to check. Try tapping the top of the dashboard sharply, and see if it has any effect on the gauge to confirm.DHFiS wrote:Brass nut on the back that earths the gauge to the circuit board?
Nut is on the back of the cluster case, right behind the gauge. Temperature gauge has one as well, so check that at the same time.
If this cures the problem, then case closed, but if it doesn't, then the problem is likely to be with one of the two level senders in the fuel tank.
Either post again for instructions on how to determine which sender is at fault, or use the search function to look back at previous posts where I've described how to do this.
M3KUK
OK had the dash out a few times recently so that might be it.
Thanks.
Thanks.
M3KUK
Checked the nut behind dash it's not that. Must be the senders?
Probably A sender. Unlikely to be both.M3KUK wrote:Must be the senders?
Ensure that you have less than half a tank of fuel, then remove one of the inspection panels under the rear seat base, pull off the sender plug and use a short piece of wire to short out the pins in the plug, then drive the car as normal.
The gauge will read twice what it should, but you are looking to see if the gauge still jumps.
Replace the plug on that side, then remove the cover on the other side and repeat with the sender plug there.
When you determine which shorted plug gives a stable reading, the faulty sender is the one still connected on the other side.
Some versions of the sender can be dismantled and repaired.
M3KUK
Thanks Brian will give it a go.
M3KUK
Looks like it's the sender on the passenger side. It stops jumping around with it shorted out.
The fuel warning light still works ok funny enough!
That will be the problem then!M3KUK wrote:Looks like it's the sender on the passenger side. It stops jumping around with it shorted out.
Only time I've known a low fuel level switch to fail is when the whole RH sender has been severely physically damaged by some uniformed muppet trying to remove the fuel pump without removing the sender first.
M3KUK
Yes looks like it, thanks. I'll remove it when I get a minute.
Low Fuel light is on the other side sender, so at least I know
when there's 1.5 Gal left.
