Headlight wash wipe plumbing drawing
jimbom30cab
Tech 1 freak
Post Fri Dec 02, 2016 5:35 pm
Hi. Does anyone have a plumbing schematic drawing for the hoses which make up the headlights and washers for the hlww kit
I have a whole bunch of hoses and not sure how to fit it all together
BenHar
Post Fri Dec 02, 2016 6:12 pm
http://www.e30zone.net/e30zonewiki/inde ... mp_washers
Not sure why you've put this in the Other BMW Technical Help section, Jim.
Ben
Post Fri Dec 02, 2016 7:10 pm
BenHar wrote:http://www.e30zone.net/e30zonewiki/inde ... mp_washers
Ben
Useful though this link is, if you have HL wiper problems, it's of absolutely no use for routing and connecting hoses.
Try this, originally from my archives, and now in the wiki: http://www.e30zone.net/e30zonewiki/imag ... leaner.pdf
TriggerFish
Post Fri Dec 02, 2016 7:14 pm
I've been wondering this too, thanks Brian!
That's going to need some effort to decipher though!
Post Fri Dec 02, 2016 7:48 pm
English text is at the end, but you have to keep referring back to the German section for the pics.
90% of the article is irrelevant to what you want to know, but it's all in there somewhere.
TriggerFish
Post Fri Dec 02, 2016 8:36 pm
Ah, I didn't get to the English bits, but good to know it's there.
Trying to trace back the mess that I've got already will be the other challenge (and then making the wipers work for the same length of time each, rather than random durations etc.).
A 'one-day' thing, but at least I know the info exists now! :D
Post Fri Dec 02, 2016 8:53 pm
TriggerFish wrote: Trying to trace back the mess that I've got already will be the other challenge (and then making the wipers work for the same length of time each, rather than random durations etc.).
Both headlamp motors are triggered by a short 12 volt pulse from the control module on the washer bottle, along the black/yellow wire. Once the wipers have moved off of their stops, they are powered by the ignition switched 12 volts + on the purple/black wire, and their complete sequence of wipes is controlled by an internal cam and switch in each motor. Once the cam has done a complete turn, the internal switch opens, disconnecting the motor from the purple/black, and no further movement occurs until another trigger pulse appears on the black/yellow.
The right hand motor also contains a second cam and switch which connects the purple/black wire to the blue wire (to the headlamp washer pump) for the first part of the wipe sequence.
In short, once the wipers have started, their entire sequence is controlled internally in each wiper, and as long as power is on the purple/black, they should each complete their entire sequence of wipes and then park. If one doesn't, then the problem is inside the wiper assembly.
BenHar
Post Sat Dec 03, 2016 10:53 am
Brianmoooore wrote: Try this, originally from my archives, and now in the wiki: http://www.e30zone.net/e30zonewiki/imag ... leaner.pdf
Brian, that's a great document and thanks for putting it in the wiki.
The trouble is that no-one will find it because it is not linked to in the wiki pages.
Need someone like Grrr to add links.
Ben
TriggerFish
Post Sat Dec 03, 2016 11:54 am
That's an awesome help Brian. Thanks.
I was assuming it to be the black control module, but that's working fine by the sounds of things. Either way, something for warmer weather as it's not urgent
Post Sat Dec 03, 2016 1:27 pm
Ben
You'll find it (and the approx. 70 other guides) if you enter the wiki via the sub forum of the E30 Tech Help forum, rather than the link under the page header.
Post Sat Dec 03, 2016 1:29 pm
TriggerFish wrote:That's an awesome help Brian. Thanks.
Module on the washer bottle counts the number of times the main washers have been used with the lights on, and provides the trigger pulse after five times.
BenHar
Post Sat Dec 03, 2016 2:09 pm
I still can't see it, Brian, sorry.
What should I click on in the sub forum of the E30 Tech Help forum?
Ben
Post Sat Dec 03, 2016 6:36 pm
E30 Tech Help, wiki. Fifth post down, "retrofit guides".
BenHar
Post Sat Dec 03, 2016 6:48 pm
Thanks, Brian.
Ben
jimbom30cab
Tech 1 freak
Post Sun Dec 04, 2016 4:34 am
Thanks Brian and everyone else. .
