Injector loom
corkie
How do i remove this please[/u]
e30
Cloggy Saint
corkie
Sorry its the clips on the injectors im having trouble with i need to remove these to get at the rail nuts?
e30
Cloggy Saint
corkie
No the plastic trough with the injector clips is in the way
e30
Cloggy Saint
Easiest way is to completely remove each spring clip with a small screwdriver, making sure they don't disappear into a dark corner of the workshop as you do. With them all off, the electrics rail will pull off in one. Make sure the little rubber seals inside each plug don't get lost either.
Refit all the spring clips before reassembly - the plugs just snap into place.
corkie
All done many thanks i was told on fb this could not be done glad sombody knows what their talking about!
e30
I wouldn't recommend the tech. advice on facebook!
