where this part on exhaust?
markus_74
Post Tue Nov 08, 2016 5:57 am
Hello,
I want to install all rubber parts on my exhaust to minimize all shake cause of loss compression misfire.
But i dont know which i should install this? Or it is not need?
Thank you
Markus
Post Tue Nov 08, 2016 10:27 am
Never seen one of those on any E30 exhaust I've looked at.
Gearbox mounts are similar to this.
markus_74
Post Tue Nov 08, 2016 11:42 am
Thank you
hennabm
Post Tue Nov 08, 2016 5:31 pm
A similar mounting is used for early cars where the fuel pump is mounted on the inner panel behind the rear subframe on the UK passenger side.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
irina
Post Wed Mar 22, 2017 10:36 am
this is the stabilizater of rear exhaust, :P
