Lots of axhaust smoke
guuskolo
Post Fri Nov 04, 2016 10:09 am
good day to you all.
i have a 318I from 1985 (no kat)
ever since i bought it i've had the idea it smokes a lot, and i'm here to check if that's just me..
this was when it was semi-warm (almost 90 degrees):
sidenote: it was a pretty damp evening.
still this is not something i've ever seen coming out of a car.
i've tried pulling the plug from the enrichment injector, but that has no effect.
advice anyone?
Post Fri Nov 04, 2016 10:25 am
If that's smoke (blue or black?) then there's something very wrong. If it's water vapour (white), then it's a characteristic of most 'quality' cars. E30 exhaust systems contain a lot of metal, which is difficult to get up to a sufficiently high enough temperature for the large quantities of water produced by combustion to be expelled from the back as invisible steam.
guuskolo
Post Fri Nov 04, 2016 11:02 am
it's white.
is there a way to decrease this ?
Post Fri Nov 04, 2016 3:10 pm
Moving a long way South would work, as would changing your exhaust for a very cheap aftermarket system, the sort that lasts about two years.
It's a symptom of quality and cold weather, but should clear when the exhaust gets fully warmed up.
I notice you're in the Netherlands - the home of quality LPG conversions. Most of my cars run on LPG, which makes the effect far worse. For the first couple of miles, I lay my own personal smoke screen.
