LSD help
stuartgallafant
Post Tue Jan 24, 2006 10:19 am
hi guys, i've just managed to source a 3.91 slipper for my beast...
was just wondering if it is a large case or small case, and depending on this, will it fit straight into my 318iS or will i have to get different driveshafts aswell.
any help on this would be appreciated...
Ant
Retired Team Member
Retired Team Member
Post Tue Jan 24, 2006 1:41 pm
3.91 is a large case, you'll need to swop the output flanges over to allow you to fit this with your existing setup.
stuartgallafant
Post Tue Jan 24, 2006 2:14 pm
are they the 'cup' type things that are on the outside of the diff? the bit that the driveshafts connect to?
what do i have to swap them with?
stuartgallafant
Post Wed Jan 25, 2006 10:43 am
anyone, feel free to help!!!
ian332isport
Post Wed Jan 25, 2006 12:15 pm
stuartgallafant wrote:are they the 'cup' type things that are on the outside of the diff? the bit that the driveshafts connect to?
Yes, those are the correct parts.
You need to pull the flanges from your original diff and fit them to the LSD. They just pop out if you give them a gentle lever with a pry bar or screwdriver.
Ian.
stuartgallafant
Post Wed Jan 25, 2006 12:16 pm
Cheerz Ian...
will keep you updated with my progress
