Cab re-screen cleaner
M3Tony
Just used RENOVO plastic window polish - I was sceptical (Ԛ£5.99 for 30 ml bottle) - but really amazing traansformation !!! Think Zoner suggested it, and it really does work.
Steviec
Ive just got some too, only had time to try a little bit but it does work a treat.
Zayyan
Where does one obtain such a product?
OFG, you say it's a "polish" - is this different to the stuff that removes the milkiness from rear windows?
M3Tony
I ordered online thru www.renovointrnational.com and it arrived 1-2 days. Good Ԛ£5.99 spent....nearly as good value, as "Wild Chip"
M3Tony
apologies.....www.renovointernational.com Damn cold fingers !
Steviec
Its classed as a polish and yes it removes cloudiness and light scratches, it also helps prevent the screen from cracking (so they say).
Zayyan
Necrophilia is a crime dude.OFG320i wrote:apologies.....www.renovointernational.com Damn cold fingers !
Cheers for the link, do you reckon a 30ml bottle is enough for one milkiness-clearing session?
M3Tony
Yep, 1 x 30ml, only little bottle, but fine. I applied it is small circles all over 1st, then let dry(ish) as they suggested, and then with one of wife's tea-towels, using clean bits every so often, rubbed back off again. Came up real treat, and honestly, I'd near dammit stopped looking in rear view. I tried a little on the inside too, mainly just a light wide spread, to clean rather than polish. I've got maybe 25% left, so enough for touch up or thin wipe over again.
Fingers warm now, been bow-sawing fire wood....!
Zayyan
Sounds great for the money, it only seems to be Ԛ£5.59 as well
Steviec
I never realised that I had just as many scratches on the inside as on the outside. Hopefully we will get some good weather this weekend so I can wash and polish the cab and sort out the coupe to ebay it.
adam3442
Just ordered some too, guess i'll have to start using the rear view mirror again
Ordered some hood revivor too so i'll let you know how good that is..
