Looses power/ vibrating
ETERNITY
Post Fri Oct 07, 2016 6:37 pm
325i sport
The power cuts out for a second then revs fly up and car accelerates hard.
It's not as silky smooth as it was, I can feel a viabration inside the cabin as am accelerating also as am resting my foot on the clutch I can feel the vibration of the engine.
This starting happening after I replaced the clutch last year.
Recent Work done
Fully serviced, cambelt done,clutch replaced last year,
Afm changed, new exhaust
Any ideas folks what I should be looking at
325i sport tech 2, lach silver, 1989, BBS RS 16 split rims,
[URL=http://s878.photobucket.com/user/ETERNI ... 0.jpg.html][img]http://i878.photobucket.com/albums/ab35 ... 46cc30.jpg[/img
Post Fri Oct 07, 2016 7:04 pm
Clutch/flywheel assembly out of balance, perhaps?
Also inspect the engine mount rubbers.
What age is the car? Early pre-facelift 325i had a crank sensor on the flywheel, which can fail causing such issues.
ETERNITY
Post Fri Oct 07, 2016 7:57 pm
Speedtouch wrote:Clutch/flywheel assembly out of balance, perhaps?
Tech 2, 1989..
Now u mention the clutch/flywheel is out of balance you may be right because the revs come down really slow
Thank you for your reply
Post Sat Oct 08, 2016 11:01 am
I would do the usual checks for low idle speed first - clean the ICV, check the TPS, check for air leaks around the inlet manifold, vacuum hoses, etc.
ETERNITY
Post Fri Nov 18, 2016 5:41 pm
Update:
The mechanic has advised me to change spark plugs, rotor arm, dizzy, leads and this shud resolve the issue because apparently it is misfiring. The power loss happens around 3-4K revs and then suddenly shunts forward. There is also a strong smell of petrol on cold start now.
The plugs were changed last year and dizzy/rotor arm were changed about 4 years ago.
Leads look in ok condition and I have only done about 6k miles in 4 years since dizzy is changed. I can get it all done for £100, is it worth doing?
ETERNITY
Post Tue Nov 29, 2016 7:45 pm
While changing the leads, plugs rotar and dizzy, should I look at changing anything else while that's being done.
