weight in the back
paul007
Post Fri Sep 09, 2016 11:19 pm
the e30 i was told has a weight added to the rear right had side (drivers side) because in germany it balanced the car as the driver sits on the left hand side.
is this true - i had mine removed due to this was that wrong?
Post Fri Sep 09, 2016 11:55 pm
The 'weight', (cabs only), is a harmonic vibration damper, and nothing whatsoever to do with what you've been told.
The last time Renault were to the forefront of F1, their success was largely due to the development of a harmonic vibration damper, working in the same way, hidden in the nose cone. After being discovered, it was promptly banned, and Renault's fortunes in F1 faded away.
Post Sat Sep 10, 2016 8:14 am
I have one for sale in perfect non rusty condition :D
paul007
Post Sun Sep 11, 2016 2:39 am
looks like i need to put one back in :x
Post Sun Sep 11, 2016 10:01 am
Shouldn't worry about it too much. On an E30 that is in top condition, where all the suspension bushes are good, the design of the suspension hasn't been destroyed by excessive 'lowering', you'd notice a small, but significant, improvement by putting things back as they should be, but for any E30 where each MOT test is a lottery, running on 100,000 mile old dampers and generally subject to distress servicing only, it's not going to make much difference.
Which camp is your car in?
