what im getting at is..... would a petrol tank from an 80 325i fit my 84 323i??
325-->323
gepetto
323 -->
hi, ive got a 323 that i drive daily with a few minor problems, i have 325 for parts and breaking (still got stuff if anyone needs!)
Rosco83
hey, im a friend of gepetto's and thats meant to say 88-89 325i
E30Mark
Physically i believe it will fit, but the 325i tank might have a larger capacity, have a look under both cars and see if both sides of the tanks are level or not. If you do fit a different size tank, then i guess you need to change the fuel gauge as well, or maybe just the fuel sender.
Thinking more about this as i type, does the 323i uses a external fuel pump? as the 325 one will be internal....
PM for details
PM for details
Rosco83
thanks for your reply
.... im passing on the info to gepetto as he is at work where the car is just now. I hadnt thought of the location of the fuel pump to be honest as i assumed they would be similar. Im sure he will be on at some point. He'll know more about his car than i do.
Cheers again
Cheers again
doog
The early 323, runs two pumps. A primary in the tank and a main external pump, although I have been told that you can replace it with a single in tank pump.
gepetto
thanks folks, ill take the tank out of the breaker and see. dont quote me on it but i think they are similar. worth a try, if not ill just have to part with money for a new tank
