Door adjustment
jcm325
Post Tue Aug 30, 2016 10:54 pm
Hi all, is there any way to adjust the door closer to the body of the car? The rear of the door seems to sit slightly proud of the body and I get a bit of wind noise. ..it's a 2 door if that makes any difference. ....the height of the door and the front edge look pretty good it's just the rear that sticks out.
Many thanks
TriggerFish
Post Wed Aug 31, 2016 12:53 pm
I think moving the striker plate/latch should do this. I remember it took me a few attempts to get the door to sit right as i was refitting these bits.
Rear door card/panel has to come out, and the torx screws can be access from 'inside' the b pillar.
aimlessrock
Post Wed Aug 31, 2016 8:56 pm
could the door have been damaged in the past?..I saw this on a golf once.
E30 320i Convertible (1989)
190 Mercedes (1988)
Post Wed Aug 31, 2016 10:07 pm
Striker plate sits in oversize holes, and is clamped to the B pillar by a threaded plate inside the pillar. Nothing needs to be dismantled - just slacken the bolts that hold the striker plate.
paultv
Post Thu Sep 01, 2016 5:56 am
Don't undo both torx completely as the plate will drop inside the B piller, not good.
Paul :-)
TriggerFish
Post Thu Sep 01, 2016 9:18 pm
Brianmoooore wrote:Nothing needs to be dismantled - just slacken the bolts that hold the striker plate.
Ah, yeah, my bad. I thought the bolts were accessed from within the pillar, not the other way around.
jcm325
Post Thu Sep 01, 2016 11:17 pm
Thanks guys will try it as soon as I can find a torx bit big enough! !!!
jcm325
Post Mon Sep 05, 2016 6:03 pm
Thanks everyone that sorted it!!! Door perfect now. ...for information it's a number 40 torx bit...
