Inlet fanifold, injectors and rocker cover .
trevski
Post Tue Aug 23, 2016 5:08 pm
Hi, I'm changing out the above items on Friday and would like to know what gaskets etc I will need to renew as well along the way. I have the rocker cover gasket but what else will be required please.
satan16v
Post Tue Aug 23, 2016 5:18 pm
Probably the inlet manifold gasket too
Might as well change the rocker cover breather pipe too. It's only about 15 quid and is usually blocked up with immulsified oil and crap. It runs from the rocker to the throttle body if memor serves correctly
E30 325i - In progress
E53 X5 4.6is - SOLD
E46 320d Sport Tourer - SOLD
E36 M3 - SOLD
E34 535I Sport - SOLD
trevski
Post Tue Aug 23, 2016 5:24 pm
Thanks for that I'll pick them tomorrow
aimlessrock
Post Tue Aug 23, 2016 11:51 pm
I would also look to overhaul the TB, couple of gaskets and a new rubber bung.
E30 320i Convertible (1989)
190 Mercedes (1988)
aimlessrock
Post Tue Aug 23, 2016 11:52 pm
What engine btw?
190 Mercedes (1988)
trevski
Post Tue Aug 30, 2016 7:24 pm
M20 b25
janc
Post Sat Sep 03, 2016 8:49 am
Doing the same got two gaskets. And breather pipe but rubber bung? Didn't notice this on the parts diagram before ordering. Which rubber bung before i start? Thaks in advance. M20 B25. Just cleaning throttle body assembly and throttle position switch.
BenHar
Post Sat Sep 03, 2016 11:49 pm
Post Sun Sep 04, 2016 7:14 am
Change the rubber seals on the metal pipe that fits between the block and underside of the manifold. ( this can be a pig of a job, and getting the pipe in or out is NOT possible with the manifold in place.
On reassembly you need to compress the spring right down and use cable ties to keep the spring compressed, fit the manifold, then cut the cable ties and the pipe will pop back up into place.
janc
Post Sun Sep 04, 2016 9:53 am
Thank you for the information. Haven't started yet. Where does item 26 fit? Guessing near TPS? Or on the throttle body? Trying to get straight. In my head first.
