Rear shock lower bolts
sadham
Post Tue Aug 16, 2016 10:22 am
Hi,
I need 2 lower bolts for the rear shocks as I had to cut mine off. They are NLA so was wondering if there are any other BMW's that have the same spec/sized bolt? It's a pre facelift e30.
Or if anyone has any that they are selling?
Thanks.
Post Tue Aug 16, 2016 1:56 pm
Only the E21 and E30 share the same 65mm bolt. The later cars use a 60mm bolt, which I'd consider to be close enough.
