Flat & Polish Queries??
Doink1
Post Thu Feb 17, 2005 12:23 pm
Hi guys,
I have a Red 325i convertible thats starting to turn the dreaded pink,
What I'm after is if I flat and polish the car will that return the colour or will I need to get a fresh coat of colour put on in order to keep the Red looking good.
Ie, Is it the clear coat or the paint that is ruining the colour??
Steve :)
kevin316i
Post Thu Feb 17, 2005 12:43 pm
The red should be a flat colur, i.e. no clearcoat, so you could try T-Cut to remove the pink oxidised paint and then give it a good coat of wax polish to protect the feshly cut paint. There are colour coded waxes available, so this might finish it a bit better than ordinary wax. Once you have a godd finish, its important to wax regulalry to keep it.
CaesarBob
Post Thu Feb 17, 2005 1:54 pm
TBMW did an article ages ago about restoring the finish on a terminally pink E28. They just hired a buffing machine from the likes of HSS and buffed the paint work. This worked a treat in the pics but you have to be very careful around the corners and edges as you'll easily take all the paint off.
A thorough T-cut and polish should have similar effects tho.
'97 E36 B3 3.2 Touring - Alpina-Blau
'15 F32 420d M Sport Coupe - BMW - melbourne-metallic (Sold)
'11 E92 320d M Sport Coupe - BMW-saphirschwarz-metallic (Sold)
'99 E36 328iA SE "Shooting Brake" - BMW-titansilber-metallic (Sold)
'89 E30 325i
Doink1
Post Thu Feb 17, 2005 2:48 pm
Cheers fellas,
I have recently got a load of Meguiars stuff including paint scrub so I'll give that a go.
Steve
