Hi,
I have a preface lift with girling front calipers on 45mm struts. Will girling calipers from 51mm struts fit?
girling caliper fitment
Motorhole
They will, but you will have to fit vented discs and matching pads from 51mm strut models also. 45mm strut models were fitted with solid discs which are narrower.
sadham
thank you for the info
