Door striker torx removal
paultv
Post Thu Jun 30, 2016 1:54 pm
I need to adjust my door striker positions - both doors have knackered torx 40 heads - some moron has been at the car with a can opener - so it's a drill and Easy Out job I guess, don't really want to start at it with a chisel!
ideas?
Paul :-)
jimbom30cab
Tech 1 freak
Post Thu Jun 30, 2016 2:21 pm
I had the same and used a dremmel to make a deep cut in the head then a v large flat head screwdriver to remove if that helps
scottybeemer
Post Thu Jun 30, 2016 2:22 pm
try welding a nut on
"you aint gonna take me alive, copper"
andysheep
Post Thu Jun 30, 2016 2:43 pm
jimbom30cab wrote:I had the same and used a dremmel to make a deep cut in the head then a v large flat head screwdriver to remove if that helps
I did the dremel slit,and with a flat head drive on a wrench it works a treat and no paint damage,which is more likely with welding :mad:
paultv
Post Thu Jun 30, 2016 2:58 pm
Great - cut slots and used a flat headed driver - less hassle than expected - time to order new bolts....
thankx
Paul :-)
