I am in need of the part number for the carbon brush that makes a connection between the horn wiring and the steering wheel.
The part im talking about has two rivets fixing it to the steering column.
Ive looked high and low on realoem but i cant see the part im after.
All Sorted thanks
Carmo13
BHadley
Go to search icon
Type in carbon brush for horn
Use slideout318i20 for author
Part numbers for everything there
Part is shown where it logically should be in the ETK, as part of the steering lock assembly, which it is fitted to: http://2009.bmwfans.info/parts/catalog/ ... on_switch/
Carmo13
Thanks for the help chaps.
I will look a bit closer to the diagrams next time!!
