Brake lights won't go off
Cloggy Saint
scottybeemer
is it not a switch on the pedal assy
"you aint gonna take me alive, copper"
Cloggy Saint
jmc330i
Have you refitted the same servo or fitted a different one?
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Cloggy Saint
jimbom30cab
- Tech 1 freak
Sounds like the pedal is not going high enough to activate the switch. BMW have measurements for the pedal height , am sure I saw something maybe on the wiki. The brake rod can be adjusted to get the pedal height back up. Assuming the switch is still plugged in.
Cloggy Saint
If the original servo is back in where it was, and the push rod hasn't been adjusted in the meantime, then the pull rod that goes across the car behind the heater box needs shortening to lift the brake pedal up to just short of as high as it can be lifted.
Rod has locknuts that need to be loosened, a RH thread at one end, a LH thread at the other, so it can be shortened or lengthened by turning it, and a couple of flats, just where it passes the clutch pedal, so that it can be turned with a small spanner.
Cloggy Saint
LH drive car doesn't have a pull rod, so adjustment is solely by the servo push rod, but because there's nowhere near as much linkage, a LH drive car should rarely, or never, need adjusting.
Cloggy Saint
Cloggy Saint
