E30 325 power range
Stee09
Post Sat Jun 04, 2016 6:59 pm
It it normal for the power band to only be 5200rpm to 6300rpm, the rest seems fairly slow then a lot of power in this rpm range
sweep
Post Sat Jun 04, 2016 8:34 pm
Does it have a cam in it like a toblerone?
Stee09
Post Sun Jun 05, 2016 5:11 am
Ehh cam is fine mate lol
sweep
Post Sun Jun 05, 2016 8:40 am
Is it a high lift one or standard?
Stee09
Post Sun Jun 05, 2016 12:57 pm
Standard mate
mbraun
Post Sun Jun 12, 2016 4:43 am
have you recently put in a new timing belt? Is it possible that your cam timing is off one tooth? A cam timing change will move your power band
M3KUK
Post Sun Jun 19, 2016 1:54 pm
6300 revs? A bit high that innit? Chipped?
Should be loads of power all through rev range if std.
reggid
Post Sun Jun 19, 2016 11:29 pm
should feel a surge at 3500rpm and should push you in seat hardest at 4500rpm and slowly taper off to cutout at 6400rpm ish. you dont feel power you feel the torque as thats what gives acceleration.
Also toblerone (pointy/spiky) cams are usually low duration. if the nose of the cam is big radius its a big duration cam
E30 325is with M20B31
