m20 engine mount cup cap function?
markus_74
Post Tue May 31, 2016 11:39 am
Hello,
I need to know what function of this part?
Do this part important to isolate the engine vibration?
My engine mount without cup and now stretching or is this normal?
Thank you
Markus
Post Tue May 31, 2016 12:27 pm
Limts the engine movement under acceleration, braking and cornering.
markus_74
Post Tue May 31, 2016 1:20 pm
Thank you Michael
Post Tue May 31, 2016 8:38 pm
They don't really make much difference at all, look how much of a gap is around the mount, lots of room for movement
Post Tue May 31, 2016 10:36 pm
Brianmoooore wrote:Limts the engine movement under acceleration, braking and cornering.
As brian said, i've had these on my car for ages, and still running the mounts without any damage.
And Dan, pi55 off with any smart arss3 comments. :wink:
Post Tue May 31, 2016 11:09 pm
Pardon? I don't know what you mean! :o
Is this the garage queen/laid up turd that hasn't been driven for 8 years? :D
Post Wed Jun 01, 2016 12:17 am
4 years to be exact :wink:
markus_74
Post Wed Jun 01, 2016 10:19 am
Thank you for all advices.
markus_74
Post Thu Jun 02, 2016 5:33 pm
I think I will make it with aluminum or metal locally.
Any info.how much the gap.between rubber and metal? And how much height?
Post Thu Jun 02, 2016 7:47 pm
I make these if I want engine mounts to be stiffer
markus_74
Post Fri Jun 03, 2016 2:58 am
Thank you for the picture, is it no gap between rubber and aluminum? Or 1 mm?
Does the vibration to the body increase a lot or minor?
