Red to Blue Coolant
RobWill116
Post Sat May 28, 2016 7:51 pm
Hi all,
I've currently got red coolant in my e30, and I am wanting to change this for blue coolant which should be in it.
How can I ensure that I don't mix the two? Will the usual flushing process mentioned in the wiki suffice?
RobWill116
Post Mon May 30, 2016 11:11 pm
Bump
Cloggy Saint
Post Mon May 30, 2016 11:54 pm
To completely replace the red coolant you'll need to flush the block too.
Yeti
Post Tue May 31, 2016 1:35 am
remove thermostat, pull top hose off and pump water through it whilst its running
RobWill116
Post Tue May 31, 2016 12:39 pm
yeti wrote:remove thermostat, pull top hose off and pump water through it whilst its running
I'm guessing to flush the heater matrix I will need to leave it on full hot also?
So basically remove thermostat, pull top hose off, put hose pipe in, fire it up and keep the water running through until it runs out clear
