electric windows
j4gz
My 30amp Fuse keeps on blowing for the electric windows even though the window button is not pressed i have changed this about 4 times now what could possibly be the fault ?
BenHar
Likely to be a broken wire.
Check where they go into the doors.
Ben
Ben
check for metallic debris (pin, aluminium foil, etc.) inside one of the switches. Also check that something "aftermarket" hasn't been wired into the window circuit.
j4gz
Brian you are a absolute legend you were exactly right about the switch thanks for your help ...
