Andy
Tranny oil?
andysheep
Got the cabby back from mot
first time on the road in 7 years,i need to change auto transmission fluid and tips and oil recomendashions chaps,its a sports switchable 320i,thanks folks
Andy
Andy
andysheep
Bump?
manse73
Make sure you do the filter in the box too
bruv chariots rule
andysheep
I was thinking about that,not many pennies too,but im wondering if all oils are equal?
manse73
Always use a good quality oil. If it's £25 cheaper it's no good. That £25 saved could cost thousands down the line
bruv chariots rule
darkchild
Dexron III is what you need (which replaced Dexron II). No fancy expensive oils like modern auto BMWs. Definitely do the filter at the same time - like you say, they're cheap enough.
The gearbox oil should be changed every Inspection II iirc but Dexron III ATF is so cheap that I've tended to change mine every 20K.
darkchild
It only needs standard Dexron III changed at regular intervals.manse73 wrote:Always use a good quality oil. If it's £25 cheaper it's no good. That £25 saved could cost thousands down the line
manse73
It's been stood for 7 years change the filter as well
bruv chariots rule
darkchild
darkchild wrote:Definitely do the filter at the same time - like you say, they're cheap enough.
bab-91
The title of this thread was misleading.
IG - bab91
IG - bab91
andysheep
Yes it was
but i got what i needed,us chefs all have filthy minds so im at home here
