As said in the welcome post i have an e30 318is on a h plate on my drive i am trying to get road worth again.. few issues we currently have
I always work on my own cars so these questions are a bit e30 specific
We have got it running nice and all brakes are working and running seems to be okay, except needing to get rid of the stupid welded diff
First problem..
Interior fan catching fire
Pretty much.. turn it on couple mins later.. lots of smoke horrible electrical burning smell..
How do you go about changing it?
Rev counter doesn't work..
Do these have batteries behind the clocks like my dads e28 m5?
If so how does clocks come out, if not where else should i look.
It has 14 inch alloys on which rub the tie rod. So guessing the is came with 15s or bigger? I havent driven it don't worry
Can't get in book or petrol cap.
They seem to be seized shut, is there an easy way in or just lots of spray with wd to try get it to free off.. i haven't tried going from inside the car yet as low down on my list. Butnis that possible..
Rear dounut is knackered.. easy/how to change
Many thanks for any help you can give in bringing this back to life
Pete
