91 325i radiator bleeding
UniqueAutobodies
Post Wed May 11, 2016 8:13 pm
Hi there
Im fittin a new radiator after changing my engine recently and need some help as there a pig to bleed
Has anyone got any links to a deecent write up on bleeding the system?
cory58
Post Mon May 16, 2016 9:59 pm
Wouldn't it be the same as refilling and bleeding with an existing radiator? Just use the bleed screw on top of the thermostat housing.
1992 325i Cabrio
1988 320i Touring
2015 328i
2001 325i (R.I.P.)
jcm325
Post Mon May 16, 2016 10:10 pm
Mine was awful to bleed after a coolant change, as above use the bleed screw on the thermostat housing be careful with it though as it's probably shagged! !!!
Top up with coolant then run the car with the heater on full heat at speed 4 ,obviously just watch the temp gauge and bleed out of the screw topping up with coolant as required, in the end I had to put the car on a steep hill nose up and rev the shit out of it to get the coolant to circulate. ...
Then take it for a drive and probably repeat a couple of times for good measure. ...also make sure fan clutch/fan shroud and thermostat are good or you're wasting your time.
