gearbox linkage
keith52
is the gear box linkage different in length from a 320 to a 325 ? the part that connects the gear stick to the gear box Cheers Keith
Templ8e30
Yes it is, the 325i box is slightly longer than the 320i box so needs its own prop and linkage.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
keith52
Thanks Iain, i thought so .i've changed the prop but left the linkage as it was really tight but now the stick is a bit to far forward Cheers keith
keith52
I meant no sloppyness
Templ8e30
The stick sits closer to the dasboard, I found that out when fitting a 2.7 with 325i box to my 320i
Cheers,
Iain T
Cheers,
Iain T
Geeman
Well, that's good to know. I never knew that!
I thought all M20 box's had the same casings.
Templ8e30
Nope !Geeman wrote:Well, that's good to know. I never knew that!
The 325i box is approx 38mm longer than the 320i box
Another bit of hard learned info
Cheers,
Iain T
