Touring rear washer leak
cory58
Post Sun May 01, 2016 5:27 pm
Hello! I'm relatively new to E30Zone, but not to E30s. I currently have 2 E30s, the most recent acquisition being a 320i Touring that I am refurbishing.
I finally got the rear washer working on the Touring last weekend, but the joy was short lived. There is a leak from the wiper motor unit. The arrow below marks where the fluid is leaking. It looks to be coming from the joint in the plastic/rubber fitting, not from where the fitting goes into the motor unit.
Has anyone had this same problem? I looked at the rear wiper motor refurb DIY on the wiki, but didn't see any help for my situation. Does anyone know if the fluid fitting is actually 2 parts (fitting + grommet)? Is the fitting removable?
Any help would be greatly appreciated.
Thanks, Cory
1992 325i Cabrio
1988 320i Touring
2015 328i
2001 325i (R.I.P.)
Post Sun May 01, 2016 8:10 pm
AFAIK, the black part is all one piece, so I suspect it's cracked. Inside the gearbox there's a seal, similar to an oil seal, into which the end of the hollow wiper shaft fits. This seal commonly leaks as well, filling the gearbox with water.
cory58
Post Mon May 02, 2016 10:15 pm
Brianmoooore wrote:AFAIK, the black part is all one piece, so I suspect it's cracked. Inside the gearbox there's a seal, similar to an oil seal, into which the end of the hollow wiper shaft fits. This seal commonly leaks as well, filling the gearbox with water.
Thanks! I'll try to identify where the crack is and see if I can seal it. Probably also a good idea for me to take apart the motor unit and see what it looks like inside.
Cory
1992 325i Cabrio
1988 320i Touring
2015 328i
2001 325i (R.I.P.)
pony2
Post Mon May 02, 2016 11:08 pm
Check the pipe which runs through the middle of the motor, it can become blocked and cause pressure/leaks in the pipes.
cory58
Post Tue May 03, 2016 2:31 pm
pony2 wrote:Check the pipe which runs through the middle of the motor, it can become blocked and cause pressure/leaks in the pipes.
Thanks! Will do.
1992 325i Cabrio
1988 320i Touring
2015 328i
2001 325i (R.I.P.)
