Front passenger footwell leak
sadham
Post Mon Apr 18, 2016 9:53 pm
Hi All,
I understand this has been discussed previously but I have a leak in my passenger front footwell.
It seems to be coming from behind the grey cover in the picture. (As you can see the water stain line going down on the left side.)
The scuttle vent was clogged but I think I've managed to clear it up but the leaking is still there, admittedly not as bad but still there.
Could you let me know what else I may need to do to put a stop to it? Would applying silicone be my best bet?
fixedwheelnut
Post Mon Apr 18, 2016 10:28 pm
I would take that plate and the glovebox out then have a good look up there, chances are the windscreen is leaking or the bulkhead has rusted through behind the fusebox.
Post Mon Apr 18, 2016 11:08 pm
Those two rust patches on the glovebox bracket look very suspicious.
bimanut
Post Tue Apr 19, 2016 11:42 am
Best get your Welder out because I reckon the main loom aperture is rotten or even worse the scuttle channel
sadham
Post Tue Apr 19, 2016 11:48 am
Was dreading that, got a feeling it's most likely rust than the windscreen. Any idea of cost to get rust from there cut out and welded up? Also if you can recommend anyone in the west midlands area that can do it? Thanks
bimanut
Post Tue Apr 19, 2016 12:07 pm
Difficult to give a cost without seeing pics of total damage,best bet is to remove stuff till you've found it.If youre lucky you won't have to remove the dash.
There is a lad on fb zone advertising welding services in Birmingham and from the few pics he has posted he looks pretty decent.
Any pro Welder is going to charge £100-£150 for a full days graft,the more parts you remove the less time he spends on your car the less he/she will charge you.
I also do welding but I'm an hour's drive away in Warrington
sadham
Post Tue Apr 19, 2016 12:10 pm
Do you have a link for the facebook page? I'll try contacting the guy from there, will have to get to work stripping the car once I finish work.
bimanut
Post Tue Apr 19, 2016 12:23 pm
Best I can do I'm a welder not a PC tec lol
sadham
Post Tue Apr 19, 2016 12:35 pm
Lol that's great, I've sent him a message so hopefully my car will be sorted soon.
Many thanks.
bimanut
Post Tue Apr 19, 2016 12:38 pm
8)
Post Tue Apr 19, 2016 1:45 pm
bimanut wrote:.If youre lucky you won't have to remove the dash.
Half hour job on an E30. Dead easy.
bimanut
Post Tue Apr 19, 2016 1:56 pm
If you know where every screw,nut and bolt is.
I was talking more about cutting down on the cost on paying for man hours
sadham
Post Wed Apr 20, 2016 8:50 pm
How do I remove the black rubbery thing?
I seem to be ripping it.
